I need the measurements of the Pantah engine at the lower mounting points of the engine. They are very difficult to get an accurate measurement with the engine in the bike. Here are the two points I need....
It looks like there is a spacer on the right side (brake side), but if I can get the measurements of each side from the joining point of the engine cases, I can determine how wide the spacer needs to be later.
Thanks!
