sprocket/chain and clutch line question
bill h
Post by bill h »
i am planning to add a 42t rear sprocket and replace my chain. will i have to add a 110 link chain or will the stock 108 links work?
does anyone still make a stainless steel clutch line for a 1993 907ie?
thanks in advance
bill
93 907ie
72 norton commando
71 triumph t100c
66 norton 650ss
Re: sprocket/chain and clutch line question
GALFER makes them. You find them on ebay.
But you can also take any other if the length and the angle of the fittings is correct. The line I`m using came from a big scooter.
LudeDuc
Post by LudeDuc »
Not Sure about your chain issue; but paso750 is correct Galfer model "FK003D94CL" is made for the 907IE Clutchline, just replaced mine this spring.
bill h
Post by bill h »
thanks to all who replied!
did a google search and came up with a vendor. i went for both the brake and clutch lines/ i'll have to see if i need a longer chain when the sprocket arrives.
bill
