I have found a good source for the air temp sensor. Ducati sells the Weber Marelli ATS04 air temp sensor for about $48, BCM in New Hampshire stocks them. The other source I found is Webcon. It used to be the WAS009, that has been replaced by the WAS016, which is exactly the same. The price is GBP10.60 plus shipping. Contact info below:
Allan Smith
Technical Sales
Webcon UK Ltd
Unit A1, Dolphin Road
Sunbury, Middlesex TW16 7HE
Tel: + 44 (0) 1932 787100 | Fax: +44 (0) 1932 782725 | Email: allan.smith@webcon.co.uk
http://www.webcon.co.uk
Air Temp Sensor
- Laddie907
Re: Air Temp Sensor
info stolen by me from Cagiva Elefant 900ie web page
Air Temp. Sensor Marelli ATS04 datasheet
215810020901 picture
http://home.kpn.nl/duran103/pics/ats04%20v4.pdf
this datasheet is handy for testing the ATS resistance
Alternatives Jaeger
Meat-Doria 82042
Beru 0 824 111 010 picture
OEM / Wholesale Alfa Romeo 60806471
7547976
Aston Martin 0820003
Bresch 82.042
Fiat 7547976
Ford 6740335
YB01744
Iguacu 901
Intermotor 55705
Maserati 470079700
MTE-Thomson 5053
Webcon WAS009
5810020901
Alternatives Jaeger
Meat-Doria 82042
7547976
Bresch 82.042
Fiat 7547976
Ford 6740335
YB01744
Iguacu 901
Intermotor 55705
Maserati 470079700
MTE-Thomson 5053
Webcon WAS009
5810020901
Re: Air Temp Sensor
Not stolen, just borrowed
I had a hard time sourcing many of the numbers on your sheet in the US, maybe you can do an update with the new number replacing the WAS009 with the WAS016 and the contact info?
Re: Air Temp Sensor
Thanks for the info, I'll update the Webcon part no. on the Elefant's EFI website as soon as possible. There is already a link to the Webcon website over there, so adding contact info is not necessary.
@ Laddie: You cannot steal any info from that website
, it is there to take. And guess where I got the info from in the first place? It only took me several years to gather everything together, especially the cross reference no.'s from OEM and aftermarket suppliers.
