donaldo duck!
- year: 0
donaldo duck!
tell us about the rear brake conversion on your bike.
Re: donaldo duck!
brake conversion ? Isn`t that the standard brake of the 907ie just with countless holes in the caliper mounting bracket ?
- DonaldoDuck
Re: donaldo duck!
Thanks for the question, but they are the stock goldline Brembos that came on the 907 in 1992.
You can count the holes though. There are 12!paso750 wrote:brake conversion ? Isn`t that the standard brake of the 907ie just with countless holes in the caliper mounting bracket ?
1992 907ie Beauty. Custom high pipes, Pro Italia chip, Barnett performance clutch, Corbin Seat, Stainless brake lines. 35,000 miles. Owned since 1993.
Re: donaldo duck!
Are all those shiny parts chromed or polished ?
Re: donaldo duck!
I think the answer is:
BLING!!!
Standard caliper bracket w a few holes & polished.
BLING!!!
- DonaldoDuck
Re: donaldo duck!
Exactly! Easy way to make my bike different from any other 907ie or Paso. All polished original parts except the custom exhaust.Tamburinifan wrote:I think the answer is:
BLING!!!![]()
Re: donaldo duck!
N...ice
- year: 0
Re: donaldo duck!
DonaldoDuck wrote:Thanks for the question, but they are the stock goldline Brembos that came on the 907 in 1992.
You can count the holes though. There are 12!paso750 wrote:brake conversion ? Isn`t that the standard brake of the 907ie just with countless holes in the caliper mounting bracket ?Jeez I took your metal as a 750 didnt I should av got a 907ie seems like the finished paso! must jump into the forum for this bike maybe ill change to one then if i can find one,thanks again desmodave.
