tyre pressures
- year: 0
tyre pressures
what are the correct pressures in p.s.i for the michelins ive seen 33 and 38 somewhere but are these for the pirellis?
Re: tyre pressures
Hi, the michelin pressure guide says 2.2 and 2.4 bar, converts to 32 and 35 psi, but I run mine a little harder at 34 and 38 psi.
http://two-wheels.michelin.com/2w/front ... 4a424b424a
- Desmo_Demon
Re: tyre pressures
I think I'm running 38/38 psi because I mainly commute with the bike. If it wasn't for the commuting and lack of tire availability, I'd probably try 36/36.....but I'm not very small, either, so a higher pressure is probably better (with full gear, I'm around 260 pounds).
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- year: 0
Re: tyre pressures
amphilex wrote:Hi, the michelin pressure guide says 2.2 and 2.4 bar, converts to 32 and 35 psi, but I run mine a little harder at 34 and 38 psi. Thanks for reply i'm not too far out eh? the rear is important because of the pillion and load!
- year: 0
Re: tyre pressures
Thanx sounds like your sorted! cheers dave.Desmo_Demon wrote:I think I'm running 38/38 psi because I mainly commute with the bike. If it wasn't for the commuting and lack of tire availability, I'd probably try 36/36.....but I'm not very small, either, so a higher pressure is probably better (with full gear, I'm around 260 pounds).
