Yes Ken San, it will do about 165 mph.
Murayama Motors Paso
- JWilliam
- year: 1989
Re: Murayama Motors Paso
Your PASO looks fast, too.
- Ken@Murayama-Paso
- year: 1989
165 mph!? incredible speed!JWilliam wrote:Yes Ken San, it will do about 165 mph.
Is it 750, 906 or other special engine?
My Murayama-Paso(not racer) do about 125mph/8500rpm.
And Weber DCNF is screaming when it do max speed.
Murayama Paso http://ameblo.jp/ducati750/
Bimota SB7 http://ameblo.jp/bimota-sb7/
Ken's Videos http://zoome.jp/ken_works/movie_list/
- JWilliam
- year: 1989
It is a 906 machine and I have done almost everything I know to make it fast. It will do 120 mph in 4th gear. Went for a ride with other Ducati riders a week ago and a guy with a 996R had trouble keeping up, very funny. The engine has standard crank, rods and cams.
never mind, but hard to believe that a bike that normally hardly goes over 210km/h would run 265km/h without huge modifications (considering it`s not in free fall
What was done ?
What was done ?
There is a lot to be had by getting the dcnf setup properly in combination with airbox mods and better exhaust I have been fiddling with mine and I am simply amazed at the difference in power,more on this later............still have a few more things to try
- persempre907
Turbo?, NOS?, what the hell did you on the engine to run so fast with stock crank, rods and cams???JWilliam wrote:It is a 906 machine and I have done almost everything I know to make it fast. It will do 120 mph in 4th gear. Went for a ride with other Ducati riders a week ago and a guy with a 996R had trouble keeping up, very funny. The engine has standard crank, rods and cams.
Very curious.
- JWilliam
- year: 1989
I am of the opinion that factors like valve size, cam lift and rod weight etc are not that important but accurate carburation is, the standard jet settings are typically too lean. The Weber also responds well to positive air pressure feed to the airbox. It has an ITG competition air filter and a 2 into 1 Conti exhaust. Other tricks include heat shielding to the front manifold, running the engine at a lower temperature (which I can do because it is water cooled), 5 teeth off the rear sprocket and doing something to the oil filter.* Equally important is reinforcment of the standard frame around the headstock and steel brake discs on the front(power is nothing without control).persempre907 wrote:Turbo?, NOS?, what the hell did you on the engine to run so fast with stock crank, rods and cams???JWilliam wrote:It is a 906 machine and I have done almost everything I know to make it fast. It will do 120 mph in 4th gear. Went for a ride with other Ducati riders a week ago and a guy with a 996R had trouble keeping up, very funny. The engine has standard crank, rods and cams.
Very curious.
* If you want to know the finer details I can send you a private message.
- persempre907
Many thanks!JWilliam wrote: * If you want to know the finer details I can send you a private message.
I also have 2 in 1 Conti and an high performance filter on my 907.
I don't have a less 5 teeth rear sprocket, but.....
Ken, you`ve got pm, kind of urgent.
- Ken@Murayama-Paso
- year: 1989
OK, I checked it.Tamburinifan wrote:Ken, you`ve got pm, kind of urgent.
Really nice article on your Pasos in th Ducati Magazine no 11 magazine!
Too bad I couldn`t read it....
- Ken@Murayama-Paso
- year: 1989
Oh, you got it in Tokyo?Tamburinifan wrote:Really nice article on your Pasos in th Ducati Magazine no 11 magazine!
How was the stay in there, did you find bike stores?
Yup, that is the magazine I found, 3 full pages Ken & Murayama!
Didn´t have time f Duc shops, too much work.
Just enjoyed the cool stripped bikes w 1 cyl, semi offroad tires & the long black scooters.
Cool enough.
Cool enough.
- Ken@Murayama-Paso
- year: 1989
Last edited by Ken@Murayama-Paso on Wed Nov 19, 2008 4:28 am, edited 2 times in total.
- Finnpaso
- year: 0
ABSOLUTELY ONE OF BEST EVER SEEN VIDEO CLIPS !!!!!!!! Great work from Japan !
I am waiting only, what You jap guys think about jap bikes ?????????????? Do they have that "character" ("metal in oil") ????????
GREAT !!!!!!!! I am happy again!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
