rectifier/voltage regulator
- 21783mike
I need another rectifier/voltage regulator for my 87 750 Paso, it seems she is overcharging a bit.
Thanks,
Thanks,
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
- Finnpaso
- year: 0
Re: rectifier/voltage regulator
Go for Electrex! Its best i have seen... much better than stock.
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
I also fitted it, no problem since.
You can buy it online (electrexworld), it costs less than the stock one, but you need to do some modification on the electrics to fit it.
- jcslocum
The wiring is crap on the Paso. You must first check all the grounds and clean them very well.
There is a thread in the 750 FAQ discussing this. The overcharging can be because of the wiring flaws casuing the RR to see a low voltage at the battery. It's not low but it over charges anyway.
going through a catalogue I found another regulator/rectifier for Ducati. I`ve seen the chinese brand Shin Yo before but mainly for motorcycle batteries or bike accessories, didn`t know they also build regulators.
Here`re the instructions: http://www.box.net/shared/qbf2huusee
as a part from China it shouldn`t be that expensive if one can find it somewhere.
- year: 0
I also changed but still got flat batteries becauase they sent out wrong diagrams for the wiring connections you have to try opposite way round according to which phase alternator you have, so try it! (if you still get flats) Ive run mine like this, I believe they sent out new diagrams and im sure its in the faq somewhere on this site. ok desmodave.....p.s you might lose your side stand light too when fitting the new reg.
- 21783mike
Did the wiring upgrade and now with less drain on the system it is really overcharging. It'll peg the meter which goes to 16V at anything much over 5,500 rpm. I was hoping to find a NOS or good used stock unit here to maintain somewhat original.... but no replies since this is no longer in the right place for some reason???? I'll repost in the right place and see, otherwise I guess I'll get the Electrex unit since I've already made some alterations to the stock wiring already.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
- Finnpaso
- year: 0
16V is totally too much!!!
907IE -91 red
907IE -91 red
- persempre907
So it can be damaged also the other electric and electronic components.
You have to replace it immediately.
- Desmo_Demon
Just as a "double-check".....how good are the batteries in your multimeter?
The reason I ask is that I once changed the regulator on my Harley because the meter was reading over 17 volts when I installed a new battery. Even with a new regulator, it was reading the same thing, but I decided to ride the bike since I was 1500 miles from home. I found out later that my battery in the multimeter was almost dead and was giving me a faulty reading.....I know have over 30k miles on that regulator.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
isn`t the battery in the multimeter just required to measure resistance, not voltage ? (Talking about an analog meter not a digital
However, this thread proves that the regulator should be checked before doing the wiring mod. Doing the wiring mod with a faulty regulator could create additional damage.
- Finnpaso
- year: 0
ONLY way to check battery condition, is to use it with some "hard load" and same time measure voltage drop !!!! Bad battery can have good "voltage" if NOT use of current, but that voltage can drop dramatically immediatelly, whet start to take current from battery !!! There are some quite cheap mesurement devices to this purpose, but U can do such measurement in close "car battery shop" very cheaply, maybe no need to pay anything to test Your battery condition at all.....
I give advice: buy some FLUKE multimeter to have good/accurate measurements... i know, i am elecrician...
907IE -91 red
907IE -91 red
- Desmo_Demon
All three of my multimeters are digital and need the batteries to function correctly when checking everything.paso750 wrote:(Talking about an analog meter not a digital )
I use Fluke meters at work. I cannot justify spending 10x more money for a Fluke that does the same thing as my cheap multimeters when I'll only use it 1-5 times a year. I have a compact multimeter from Radio Shack that cost $30, and I think the Fluke with the same capabilities is around $300. Even with my discount through work, I cannot justify spending that kind of money on a Fluke meter......but I would say they make the best in the industry!Finnpaso wrote:I give advice: buy some FLUKE multimeter to have good/accurate measurements... i know, i am elecrician...
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- Finnpaso
- year: 0
In "my" company (www.gasum.fi) we use ONLY GOOD meters, like Fluke is and there is no any problem to borrow such to home from workplace, if needeed... We have plenty of them there. I have in my own use 3 modells...
907IE -91 red
907IE -91 red
Fluke meters ? wouldnt use anything else
My paso is using a jap RR , I think its off a suzuki ( not sure ) , But whilst lookig for a replacement for the SS(97 . 900 ) I wound up getting an after market thing that is now apparently fitted as standard to some ducati's and honda's , and I noted that they also did one that would have suited the paso ( shin.. something ), cost about 100 euro and works fine
