Will a 750/906 rear sprocket fit on the wheel of a 907. Is it a different size/width etc? I know the wheels are different so are the hubs and the carrier for the sprocket?
Tried the search in the General Forum without any joy.
Rear Sprocket
- englishstiv
Rear Sprocket
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
- Finnpaso
- year: 0
Re: Rear Sprocket
750 and 906 have same sprocket system, but 907 have totally anotherkind (like Monsters, etc have), so 750/906 rear sprockets DONT FIT TO 907 at all.... its easier to find right rear sprockets to 907, than to 750/906... Monsters "range" is very wide, so U have to choose from them right to Your 907.....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- englishstiv
Re: Rear Sprocket
Thank you Antti
DUCATI 907ie 1992
- persempre907
Re: Rear Sprocket
...and for the front sprocket?
If I well remember the 907 front sprocket has some "offset" so is quite tricky to find.
- Finnpaso
- year: 0
Re: Rear Sprocket
My opinion is, that ONLY original Ducati OEM 15 teeth sprocket fits 100% with right offset.... It can be also, that some of those big USA Ducati dealers, like Ferracchi have some own sprocket solutuin to front. Anyway its very easy to change rear sprockets (from Monster range, where range is very wide for rear). Some 900 Monster have very close same offset, as 907 have in front, was it some 2001, or so.. remembering now only!
907IE -91 red
907IE -91 red
Re: Rear Sprocket
Think you´re right there, Antti, 2001 was the year w the longer Hyper gearshaft and therefore sprocketSome 900 Monster have very close same offset, as 907 have in front, was it some 2001, or so.. remembering now only!
w a special offset f 900 Monsters.
- persempre907
Re: Rear Sprocket
It seems to me they are still available. The brand is AFAM if I well remember.Finnpaso wrote:My opinion is, that ONLY original Ducati OEM 15 teeth sprocket fits 100% with right offset....
Could someone confirm it?
- Finnpaso
- year: 0
Re: Rear Sprocket
I can only confirm, that original 15 sprockerts are still available, cause i get some from Italy some monthes ago. They are OEM parts.
907IE -91 red
907IE -91 red
