thanks for infopaso750 wrote:the one I had was the correct one.Bitubo is making no difference shocks for paso 750-900
maybe that had something to do with your "difficulties" on the rebound adjuster. (the shocks might be designed for 907? not 100% sure on that)
750 and 900 shocks are listed with the same aplication / order number
seperate apllication for:
- 750 F1
- 750 SPORT
-750/ 900 PasoThe swingarm linkage is the same on all Pasos and the F1 and Sport shocks are shorter as the swingarm ts totally different.
G,
i was not sure of the swingarm linkage on 750-900 was the same / never tried a shock in a 750 and then in a 900..
this means i can use the same shocks application for both bikes
thanks
