My question has to do with the hose that is still there, attached to the hind-most spigot located right rear underside of the tank. Clamped midway in the length of hose is a plastic valve ("FIPSA" -- see item 9 on parts diagram 36 "California Version"), then the hose is just pointed to the ground ahead of the swing arm.
So, do I need this FISPA valve?
And what should I do with the hose?
OK, no obvious jokes HaHa
