I'm a bit baffled here. I noticed the clutch fluid on my '92 907 appears contaminated so I got ready to flush and refill, to my surprise, I cannot find a bleeder screw anywhere on the bike.
There is a aftermarket slave unit (STM) and then there's the braided line from the reservoir to the unit, no fittings just the regular "banjo" fittings at both ends.
2. Rear brake switch removal:
I need to remove/change the rear brake switch ('92 907) it goes "thru" the rear hose "banjo" fitting so if I remove it I'll have a mess and have to refill/bleed the system? or is the switch independent of this fitting?
Help!! Many thanks!!
