start motor
Duncati
start motor
Post by Duncati »
Shit f--k :,( :,( :,( start motor broke again? full battery and only a nasty click, click under the saddle :,(
Does anyone know if one from a 851 will fit?
Thanks in advanced.
Duncati.
ducinthebay
Re: start motor
Post by ducinthebay »
Maybe I am mistaken, but I thought all the starters for Ducati were the same. Here's my chance to be wrong again.
Re: start motor
Post by Tamburinifan »
Sounds more like bad starter solenoid or battery.
Start motors usually only suffer from worn brushes or bad/corroded connections.
ducapaso
Re: start motor
Post by ducapaso »
You need to go measuring voltage straight to the starter pin!
Anyway, if it's ok ( >11.5 volts), you might happen to experience a "changhing brushes job" (see in the F.A.Q.).
End of all, if the brushes are ok, all duc starters are the same
nilaus
year: 0
Re: start motor
Post by nilaus »
Sounds most likely that your starter needs new brushes.
:thumbup:
ducapiero
year: 1985
Re: start motor
Post by ducapiero »
Come on, i experienced your same damage and, fortunately, it's not so expensive to fix...
on the faq you may find the help that u need....
lamps
Piero
Duncati
Re: start motor
Post by Duncati »
Thanks for all the advice and tips, I checked voltage and ok, the bushes i replaced last summer and did notice the end of the roter shaft (the bit that makes contact with the bushes) was very dirty and worn down, could this be the reason? Anyway i am going to use the 851 startmotor and see if old one can be revised, btw i have changed the bushes 4 times in 12 years, average? btw the first time i had a local dealer do it but after putting repaired starter in the bike would not start, took bike to dealer, he looked and said the sprag clutch was worn :,( took all apart fitted new parts 700 euros, still would not start :banghead: , i noticed when they turned the engine over that everything was turning the wrong way round:wacko:
Who knows what they did wrong? :thumbup: :thumbup: :thumbup: :thumbup:
Duncati
Brutus
Re: start motor
Post by Brutus »
Don't forget a faulty spragclutch..! Mine was gone and this is noticed when the starter turns free with, in my case, a loud click at the end. The click was caused by 'grabbing on' from the sprag clutch again.
Nice tip: the sprag clutch of a 906 is now fitted on a KTM, the sprag clutch of an 750 paso is still available as a part from a mini cooper '69 !! :mrgreen: It only needs one adjustment and is quite simple. The outer ring has an edge that is 0,5mm too wide in diameter. I've turned this down by fitting it in a traditional drillingmachine and holding a file on the side.
Here's a pic:
persempre907
Re: start motor
Post by persempre907 »
Yes, but in such issue you can hear the starter engine clearly running.
No matter, great tip.
Duncati
Re: start motor
Post by Duncati »
Hi Gents, just to let you know, it was not worn brushes, the copper on the shaft was really dirty again, i cleaned it and like magic it all works again, still i have a spare startmotor, no sorry not for sale, once again thanks for all your input and advice:thumbup: :thumbup: :thumbup: :thumbup: , btw, i was looking for wheel bearings and the price i found was: euro 10,13 each front, euro 8,28 sproket carrier, is this cheap?
Duncati.
Finnpaso
year: 0
Re: start motor
Post by Finnpaso »
I dont know, is it "cheap", or "expensive" to you, but i give advice: You can find near all bearings to your Paso from good bearing shop by taking original to them and ask new one... its very simple and You can also find from these sites plenty of notes about Paso bearings... :thumbup:
907IE -91 red/metal grey
907IE -91 red
Duncati
Re: start motor
Post by Duncati »
Hi Annti, i think these are a good price :huh: my local Ducati dealer asked almost twice as much, the bearings are made by KOYO, do you know if these are of good quality?
or do you recommend SKF? this is the first time I change them, thanks in advance. :thumbup: :beer:
Kiitos
Ducati.
Re: start motor
Did they mount the sprag backwards or what?
Duncati
Re: start motor
Post by Duncati »
No, they put the housing from the startmotor the wrong way around and in doing so it changed the polarity of the startmotor making it turn backswards.
Duncati.
Finnpaso
year: 0
Re: start motor
Post by Finnpaso »
:banghead: :banghead: :banghead: Why they didnt MARKED parts, when opened starter ? :wacko:
It is also possible to put sprag clutch wrongly (talking rotation dirtection!), but that must also checked, when taking old one away. (that new one comes same way...) One time i NEAR made just this "mistake" (with my ST4S), but luckily started to think more, what is right turning direction...
For my experience SKF is high quality bearing brand :thumbup: If i can choose it, or another with same price, i allways choose SKF. :thumbup: Surely its not only good brand, but i have used SKF with good results and they are not so expensive, as Ducati uses "normal size" bearings, nothing very rare. :smoke:
907IE -91 red
