best solution for the michelin problem
Finnpaso
year: 0
Re: best solution for the michelin problem
Post by Finnpaso »
JWilliam, is that Your welded part(end od swingarm) same material, as swingarm, or some other material, like steel ?
907IE -91 red/metal grey
907IE -91 red
JWilliam
Post by JWilliam »
Well its obviously the metal same as the swingarm, you can't weld steel to aluminium!
Finnpaso
year: 0
Post by Finnpaso »
It lookeed different and thats why i asked :wink: I asked it also, cause totally different metals make corrosion, if they are welded together, but You can now sleep calmly... :thumbup: Btw, well done!
907IE -91 red
Crusher
Post by Crusher »
ved wrote:Hello,
an other solution to keep clearance
http://krueger-junginger.de/assets/images/IMG_2681.jpg
i asked the price - 535€
ved
Of all the ideas on the tyer issue this is by far the smarter option as it will still look original and yet still allow a wide range of tyers to be fitted, I think I will go this way and cheaper than 17s so cheers for the idea
