cheers Léon
I'm converting to an 180/60 zr16 Bridgestone tyre. I don't want to change anything of the driveline, but need some space to clear the tyre from the chain. I'm going to do this by offsetting the rearwheel with 5mm. This will mean that the excenter on the 'brake side' is going to be turned down 5mm and the caliper and bracket will be fitted 5mm closer to the swing arm. No problem for the caliper, one problem for the bracket as it has now little clearance at the point it's connected with the swing. I think this is managed to install it on the downside and it looks it can be connected with the frame where the centerstand is fitted. I've seen pictures with connecting rods this way:jcslocum wrote:G,
I was agreeing with you. The caliper is where you say it is. INDSIDE that radius...
check the other post about 'best solution for the michelin drama'. You'll see BMW drives around for decades with the rear wheel 3 or 4cm offset due to the disbalance of the boxer. I'm allmost sure (ducbertus wrote:![]()
Brutus, A lot of people have trouble to get the wheels in line, because the bike behaves better.
and you are making a lot of trouble to get OUT of line??? to have a bike which walkes like a dog![]()
on which planet are you on?? must be somewhere behind Pluto or something.
I'm gonna drink an extra glass of wine, because I had good laugh this evening.
Thank you very, Brutus. You're fun.
Ducbertus (Brrutus)
Taking a bit of the wheel is an option I didn't think of. This'll help for sure. I did take your advice seriously and looked further in what options would be exceptable. I've noticed that the front sprocket of an 906 is 16mm thick and the one on a paso is 12mm thick. Look below:ducbertus wrote:Hi Brutus,
I've had my wine and now sober again.![]()
putting the wheel off center is a way I wouldn't go.
BMW put their compleet drive train out of center to adapt wide section tyres. But the wheels itself stayed inline.
the chainline is also important. if you have the possiblity to move the rearsprocket more outside, you probably can make a special frontsprocket with the same offset as th rear sprocket. If you want to weld the frontsproket be aware that not all kind of steel good weldable. for instance C45 is widely used for sprockets, but not very good to weld.
An other solution could be to mount the 180 tyre and cut off the rubber that hits the chain.
those 5 or 6 mm of the surface edge are not the most important. But the sidewal must be untouched.
I'm curious to your final solution, Brutus.
Ducbertus
