WANTED 1991 907 choke cable
Heavy D
Post by Heavy D »
Does any one know if anybody is making a replacement...Called BCM and they no longer can get it or have any. I called around to a few Guzzi shops etc. and no luck.
A little help !
Thanks !
jcslocum
Re: WANTED 1991 907 choke cable
Post by jcslocum »
It's a simple cab;e, so you could have it made or make it yourself. I have one for the Paso 750 made at a local bike shop.
Heavy D
Post by Heavy D »
I pulled the cable out and yes it looks simple but there are no bike shops anywhere near me. The closest is in Syracuse 5o miles from me. Ordering on line or having it shipped is my first try before taking trips and burning up gas... I've already tried the small engine shops to no avail.
Dean
jcslocum
Post by jcslocum »
What is broken?? If the end has pulled off, get a lead split sinker and crimp it on. The cable is probably nothing special so go online and look for bike cables and order one.
Desmo_Demon
Post by Desmo_Demon »
I think Motion Pro can remake just about any cable, and they probably have the specs for any OEM cable. I know I can still order throttle and choke cables for the Dellorto twin carb conversion for my Paso through them. Worse case is that you may have to send them your cable to duplicate it.
http://motionpro.com/
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
