Hi folks:
My 907ie had no front turn signals because the previous owner didnt have them plugged in!
When I did plug them in, the left side worked fine- normal speed, but the right side blinks super-fast (front and rear).
One side normal speed, one side double fast. All the bulbs work.
Any ideas?
Thanks lots.
Sheldon
electrical issue, please help?
Re: electrical issue, please help?
Check the bulb wattages in the fast side. If not, it'll likely be the flasher unit.
If that fixes it, please see this thread! http://forums.ducatipaso.org/viewtopic.php?f=3&t=3257
My guess is bad ground/earth on the fast one.
- year: 1993
I switched the bulbs in the rear and the fast/slow swapped sides. So its the bulb. The rear bulbs are different. Does anyone know what bulb is supposed to be in there?
Sheldon
Sheldon
- ducapaso
This should be indicated in the lens. 21w/12v
ex...Red "smooth" 753349
- Finnpaso
- year: 0
Just like Nicola say, 21W, but IF U change to halogen, or LED blinkers, then You have to change blinker relay also to "clever one", like Kellerman unit, or put resistor to series with bulbs. I just put another pairs of rear blinkers to my ST2 and only way to solve too fast blinking was to buy Kellerman unit!
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
- persempre907
Try with the right bulb beforeFinnpaso wrote:IF U change to halogen, or LED blinkers
- jetboy
i just put LED blinkers on my 750 sport- but only the front - rears are still bulbs. I didn't have any trouble with fast blinking, but one small issue is the LED lights really need a full 12v or they wont turn on - with old ducati wiring the LED blinkers don't work at all with the bike off, hardly show at idle - but are bright and clear at 2000 rpm.
i was thinking of doing the rears to LED as well, but at stops im afraid they would hardly show--
