What Ducati speedo cables are compatible with the 907ie? How long is it?
Sheldon
speedo cable
Re: speedo cable
How long is it?
Always with the personal info,heh Sheldon? Wassup with that?
The answer
3 guys are standing on a bridge takin a pea
1st guys says, Man that water is cold!
2nd guy says Yea,and its deep too!
3rd guy says But it's muddy on the bottom!
The answer
- year: 1993
Re: speedo cable
Very good Higgy- but I won't know how far away that bridge is from home or be sure to get to it with the fuel I have on board without a speedo/odo cable, will I?
Gotta go pee myself now. Sock's too tight.
Re: speedo cable
Bought a new from my dealer last summer, the cable is 85cm, part# 40310011A
- jetboy
Re: speedo cable
if your casing is still good you can get a universal kit from places like motionpro - then you just cut it and crimp to the size you need.
I actually changed out my speedo to an aftermarket job and used a kawasaki kz casing - which was just about exactly the right length- and the motionpro cable-- so far so good.
