No starting/turning over/charging troubles?
And you, Antti, our electric expert
Earlier i used those cheaper batteries, but lifetime was about maximum 3 years. Then i changed to YUASA YB 16-B and that least longer, but its also more expensive. I have now 4 year old YUASA and it function very well still, but i keep it in clever charger (Benton BX-1) normally quite often. i think, that clever charger is very good investment. Anyway batteries have "good ones" and "bad ones" no matter what brand it is. Its normall to batteries... one time lucky one time not so....Tamburinifan wrote:
And you, Antti, our electric expert, what battery do you prefer & any opinion about ACC (cranking power)?
Hi Gert -- I wanted a sealed battery and read about the PC535 on this forum, then read the info at batterymart.com and was convinced. It's a little smaller than the battery box, so you can see the hunk off old radiator hose jammed in there, as mentioned in another thread, with blocks of rubber on the two sides. It is still big enough so that it sits on the rubber pads at the base of the box. Positive terminal cover is a section of bicycle inner tube.Tamburinifan wrote:Did you choose that, kurt, and if so, why?
Also thinkin bout odyssey, does it fit org battery box?
You have a pic of it mounted?
