First a thanks to everyone for the help this board has already given me in deciding to buy a Paso. There really is a wealth of information here.
My question comes from the fact I have a bunch of leftover 600SS spares from another rebuild/project bike that I'd like to use on the 906 - especially the Mikuni carbs and 17inch wheels
But........when fitting the Mikuni carbs from a supersport, how should the intake mainfold vacuum input to the digiplex be dealt with?
If removing the Paso airbox and using pod filters can the vacuum take-off points on one of the supersport intake manifolds be used? (i.e. the holes normally blocked by a screw or used for carb sync)
Or
Should you try and retain the paso airbox connected to the mikuni's? Is that possible?
Or maybe I have got it wrong and there is no problem??
Mick
