Paso Dell Orto conversion
Just wondering, fore those who are running Dells, what size are you using? Would a 32mm work on my 750 Paso?
- ducapaso
Re: Paso Dell Orto conversion
36 fit good on stock 750 and 40 are ok for tuned 750 & 906.
you can make a search for this
ex...Red "smooth" 753349
yeah i've read about people using 36 and 40 but i found a pair of 32s pretty cheap and was wondering if those would work
- jcslocum
Probably too small for a 750....
Yeah, I was thinking that they probably would be too small, thanks
- whitepaso
Have 36mm Dellorto PHF's on mine; runs great. You'll need nice high quality air filters like K&N's too. I have oval body filters that fit very nicel
- ducinthebay
Actually, the 32's should work just fine. You will loose a bit of top end from running 36 mm carbs, but it should run pretty good. The older 750s and I think the 860 had 32mm carbs. 850 Moto Guzzi ran 32, and I think the Norton did also. Some stock 750 twins ran a 28, like 70s Triumphs. If they are cheap and clean, it could do you well until you find some cheap 36's (not too likely though)
I agree, 32's should run just fine. I can't even remember the last time I ran over 100mph
actually I do remember just don't want to talk about it,was very expensive
- jcslocum
The Paso runs bigger valves (cams too) and flow much better than the early pantahs so the 32's will really choke it and run it lean. I would look for a set of Monster Mikuni's.
