Need pictures of 750 and/or 906 carburators.
Speedmade
Post by Speedmade »
I am in need of pics of the original Weber carbs that came on the Paso's for comparison purposes.
Thanks for any help I can get.
silverfox
Re: Need pictures of 750 and/or 906 carburators.
Post by silverfox »
I have one sitting on my shelf for 750 - what parts of the carb are you interested in pictures of.
Tony
Speedmade
Post by Speedmade »
Tony,
I appreciate it. I'm looking for pics of the top, bottom, and the side with the fuel inlet on it.
I am trying to compare it with a VW carb.
Thanks.
Reed H
silverfox
Post by silverfox »
Here you go
Hope this helps
VW carb??? be very careful or you'll end up like me when I changed to Mikuni - detonation is a bad thing :-(
fasterdammit
Post by fasterdammit »
Wait, Tony, you swapped to Mikunis and then wound up with detonation? I'm contemplating the Mikuni swap myself ... any words of wisdom to share on that prior to me finding out the hard way?
1988 Paso 750 #753965
1997 Monster 750
search for the post here on mikuni base jetting setups,seems to me there are several jetting setups to get you started in the right direction
Speedmade
Post by Speedmade »
Tony,
Thanks again. That really helped.
I'm not trying to use VW stuff on a Ducati. Just comparing different DCNF carbs.
Reed
The VW guys have taken the vast majority of 42 dcnf's The 44dcnf's are used mainly for Ferrari and Maserati enthusiast. You can still get a new 42dcnf but good luck with the 44
