Conical spacer outer diameter in 907IE rear axle???
- Finnpaso
- year: 0
If someone knows outer diameter of that spacer, it would be nice to send it to Gerhard, as he needs to know measurement. My both spacers are in my bikes, so its impossible to measure them, as there is no space enough for meeasuring tool.... Easy to measure, when rear wheel is out....
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
Re: Conical spacer outer diameter in 907IE rear axle???
thanks Antti. I`ll make it 5cm that should be fine. The swingarm is 8cm high.
- englishstiv
I am having to measure with a rule at the mo' as I can't get to my tools but the outside width is 46mm, inner hole width is 25mm, outer edge is 3mm and inner edge is between 5mm and 6 mm
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
- Finnpaso
- year: 0
...just right part!
907IE -91 red
907IE -91 red
thanks a lot !!!
