300mm cast iron brake rotors on ebay
samandkimberly
Post by samandkimberly »
http://tinyurl.com/nb7b8r
These would be a very nice upgrade for anyone with he earlier 300mm rotors at a possibly very good price. I've got the high bid in for them, but I forgot that I have the later 320mm ones so I won't be bidding any higher.
Sam
Re: 300mm cast iron brake rotors on ebay
Oh look, a bidding war in progress,. Still cheap if you need them. Not much time left, a little over 100 bucks presently only an hour left.
persempre907
Post by persempre907 »
I have got them on my red 907, even if they have golden center.
Really, I paid them more than €. 400, perhaps €. 440, can't remember exactly :,( :,( :,( ...
Post by Tamburinifan »
What brand are they?
Are they cast iron?
Weight compared to original?
persempre907
Brembo cast iron, with the same shape of the stock ones on 851/888/916 SP or 900 SL/Final Edition.
Really, I didn't care the weight at all. When I bought them, they were the only rotors which fitted on earlier 907.
Jaffa
Post by Jaffa »
Whoa, am I understanding this correctly, that the standard disks on these models fit the earlier 907's??? 300mm or 320mm diameter rotors???
:wacko: :wacko: :shock: :shock:
persempre907 wrote:Brembo cast iron, with the same shape of the stock ones on 851/888/916 SP or 900 SL/Final Edition.
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
if you´re looking for 320mm discs they are basically the same on all newer Ducs, Cagiva, Guzzi & Laverda.
Regarding 300mm disc interchangeability there`s info in the FAQ.
I don`t think it`s possible to use 320mm discs if your bike originally came with 300mm discs.
persempre907
paso750 wrote:I don`t think it`s possible to use 320mm discs if your bike originally came with 300mm discs.
Just change the front fork...
Thx, frankie! :thumbup:
persempre907
Jaffa wrote:Whoa, am I understanding this correctly, that the standard disks on these models fit the earlier 907's??? 300mm or 320mm diameter rotors???
Earlier 907s fitted the 300mm rotors, later 320mm.
Tamburinifan wrote:Thx, frankie! :thumbup:
:thumbup: :thumbup: :thumbup:
I got them f 280$. :cool: :)
if one doesn`t mind a modern design you can find new discs for $240.
http://cgi.ebay.com/Front-Floating-Disc ... 286.c0.m14
persempre907
No brand?
I don't know, when it's matter of braking....
true, the only info I could find is that they seem to be manufactured in UK
persempre907
paso750 wrote:true, the only info I could find is that they seem to be manufactured in UK
It's not enough for me.
There are many Asian factories which do good stuff.
The fact they are made in EU, UK, Italy etc. doesn't assure about its quality.
