I picked up a 750 Paso in decent shape for little money, but as I'm slowly restoring it to it's former glory, I have found several items that are missing. Unfortunately, I cannot seem to locate these parts. Can anyone help out?!
carburator linkage (the shaft/spring/ball cup assembly at the end of the throttle cable)
chrome finishing ring (surrounds the seat lock)
small black cap on left switch pod (next to the flash to pass button)
rear turn signal lenses (mine are the red USA versions, but my lights are wired to flash; looks like the previous owner wired them but never got the amber lenses--either will work)
Thanks!
Rick
Difficult to find parts
Rick
2004 BMW K1200RS
2004 Royal Enfield Bullet 500
1988 Ducati Paso 750
1981 Honda CBX 1050
'It's not the kill, it's the thrill of the chase"
2004 BMW K1200RS
1981 Honda CBX 1050
- jcslocum
Re: Difficult to find parts
I'm guessing that you still have the Weber carb on there. I'll look thru my stuff to see if I have anything that might look like it.
The electrics are not bad and I have never heard of one being swapped out. Read thru the FAQ and you will see some info on upgrading the electrics and fixing it up.
Yes, it's the Weber. Previous owner rigged a contraption that worked somewhat, but not very smoothly. Everything from the cable-end back is missing.
The integrated rear turn signals on my Paso are fine, it's the outer lenses (turn signals) that are cracked, though.
They work just as they should, except the lenses are red instead of amber. I don't know if that's a problem since all motorcycle turn signal lenses seem to be amber. Might be ok since many cars have red turn signal lenses as well...
If I can find good red ones or amber ones, it would be great.
I do have the body stripped off and I started working on the electrics and major tune up items within days of bringing it home. I work at a motorcycle shop and I can't have a Ducati leaving me stranded--the boys would never let me live it down!
Rick
Rick
Rick
2004 BMW K1200RS
1981 Honda CBX 1050
2004 BMW K1200RS
1981 Honda CBX 1050
you don't say where you are located?
- jcslocum
The Amber, Euro lens is hard but not impossible to find. Ebay is your only real option.
- Desmo_Demon
I have a pair of amber rear turn signals with one stalk broken, but I believe the lenses are still in pretty good shape. I haven't seen them in a while and would have to double-check their condition, but I did find this pictures on my website.....jklnhyde wrote:rear turn signal lenses (mine are the red USA versions, but my lights are wired to flash; looks like the previous owner wired them but never got the amber lenses--either will work)
I don't have anything else that you need, though.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Thanks for the offer, but my turn signals are integrated into the taillight; I guess trying to install Euro lenses will be an impossibility...
Rick
2004 BMW K1200RS
1981 Honda CBX 1050
2004 BMW K1200RS
1981 Honda CBX 1050
- Desmo_Demon
Aaahhhh....I understand now. For some reason it wasn't "clicking".jklnhyde wrote:Thanks for the offer, but my turn signals are integrated into the taillight; I guess trying to install Euro lenses will be an impossibility...
Someone did a half-assed attempt at the Euro taillight on my Paso and I put it back to original style by using some aftermarket turn signals. For reflectors on the turn signal part of the taillight, the guy had spray painted the housing silver. He could have at least put in some type of mirrored or reflective foil tape or something.
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
- randtcastell
"small black cap on left switch pod (next to the flash to pass button)" that part is also a moto guzzi part number. i believe the same switch gear was used for several years on LeManns. I just picked one up from my parts counter gal for US$1 at Munroe Motors SF, Ducati/Moto Guzzi.
Best, Randy. '87 Paso
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
