what, if any, PSI in forks
fredskidoo
Post by fredskidoo »
Hello all
I'm needing to know what the PSI requirement is for the forks - I've been told that the valves are there so that you can remove any built up pressure in the fork tubes. As opposed to keeping them up to a certain PSI? What gives?
Easy - E
'87 750 Paso 751412
Re: what, if any, PSI in forks
