Hi all, My 907 had a recent new clutch fitted before i bought it but the biting point is very close to the bars, this makes it tricky when changing down the gears as you slow down.
How can i adjust this ?
adjusting clutch biting point ??
injected
Re: adjusting clutch biting point ??
It's not designed to be adjustable, but you can try
a) bleeding the clutch line
b) if that doesn't help, remove the clutch pressure plate and put a small ball bearing inside the pressure plate bearing cup, ie so it lengthens the pushrod.
One or both of the above will work no probs.
Failing that you could fit a bigger bore master cylinder (eg from a later bike). Will also fix the problem.
- ducbertus
there should be a little screw in the lever (Allen 3) or you can buy a more modern lever, which has an excenter to adjust the biting point.
Ducbertus
Ducbertus
Thanks guys, I had adjusted the screw in the lever but it wasnt much better. I bled the clutch and its much better now, The fluid was black and i got quite a bit of air out of it.
I was going to go out on it to see if its a lot better but its P!55*ng it down now
Maybe tomorrow
Maybe tomorrow
- persempre907
Remember to do a very accurate bleeding work.
If not, you'll have many problem to find the neutral during the ride.
