does anyone know the size and or part number for the fork seals on a 750 sport - the forks are the standard ones - according to the manual- MIBB.
Pete
fork seals ?
- ducinthebay
Re: fork seals ?
Well, the fork tube is 40mm, but I don't know the outside dimension or the height. If you take out the seals, the size is usually on the seal. Should be an easy seal size to find, unlike the M1R which has a 41.7mm fork tube.
- snakey
- year: 1989
Re: fork seals ?
ducinthebay wrote:Well, the fork tube is 40mm, but I don't know the outside dimension or the height. If you take out the seals, the size is usually on the seal. Should be an easy seal size to find, unlike the M1R which has a 41.7mm fork tube.
thanks for that - i think i have located some.
sizes that i have been given are 40x52x10 with part no 754905( http://motorcycleproducts.co.uk/catalog ... 43795.html )
Pete.
- ducinthebay
Re: fork seals ?
If you have a choice of makers of seals, Fruendenberg NOK makes some of the best ones. My local suspension shop uses them when ever they can.
- whitepaso
Re: fork seals ?
For what it's worth, when I replaced the seals in my M1R's last year, they were readily available from Parts Unlimited for a fraction of the cost from Ducati. When they arrived, they were from the same manufacturer as the original seals I removed!
A dealer should have both the seals and the wipers. For seals all they need to know is the size, which is on the top of the seal
- snakey
- year: 1989
Re: fork seals ?
These are completely wrong, too loose a fit and have fork oil squirting out of both legs now. I have tracked down some genuine ones at www.windwave.co.uk part no :- 528053 size 40x52.2x10/10.5snakey wrote:ducinthebay wrote:Well, the fork tube is 40mm, but I don't know the outside dimension or the height. If you take out the seals, the size is usually on the seal. Should be an easy seal size to find, unlike the M1R which has a 41.7mm fork tube.
Pete.
