As you can easily see, my mid-life crisis is well underway. I'm enjoying it though, and I'm ordering the plate CRIS15 for the old '82 928. Think I might get P4S0 for the bike, while I'm at it.
Seeing as I hadn't ridden a bike since 1989, and on that occasion I was forced to jump over the top of the car which wrote off my Suzuki GSX-R400, I was feeling more than a little nervous about riding it for the first time. (Not even a scratch on me that time, unlike other hits I have taken over the years.)
Starting the thing proved surprisingly easy. And the sound of it through those Stay-in-Tunes! Wow - that is pretty special. My neighbours think so too. It's even louder than the 4.7 V8.
Fortunately there's a small park next to my house, with no traffic, so I spent about 20 minutes riding the thing slowly around the park getting used to actually being on 2 wheels again. It was fairly nerve-wracking, let me tell you, and after 20 minutes I was sweating like a pig, mostly from fear of dropping it, or forgetting something vital. Like braking.
However, it does seem, that once learned, you really *don't* forget how to ride a bike! What I had forgotten though is the sensations of riding one; the noise, the smells, and the wind. It really *DOES* connect you to the road like nothing else can. And of course, if you mess up it connects you with grass, concrete, metal and other vehicles too - so I am being spectacularly careful on this thing: every other road user is my mortal enemy.
I have a destroyed left ankle (Massive Potts fracture - Paragliding, not riding), which only allows me a small amount of flexion, so changing gears is not as easy as it should be, and I have found a false neutral between every single gear, already. It'll be better when I get my Alpinestar Tech 2s in the mail this coming week. I had thought I might need to modify the gear change to let me easily swap cogs, but that won't be the case, I'm sure.
The Paso is *very* different to the old inline 4s I used to ride in the 80s, and the V-twin is far more relaxing to ride, I think. Those 4-pot bikes used to scare me. Which I absolutely loved at the time, I must say. It was my view that I would never survive to turn 25, so I gave up on bikes after the last crash, thinking discretion was the better part of something or other. (I once completed the Christchurch-Queenstown run of 530 km in 3:27:00 including stops for gas on a GSXR-1100 back in 1988 -using over 100 litres of fuel. Yeah, I was called Mr. Nutzo McSchizoid back then.)
I haven't had it over 5,000 rpm yet, and I am taking it very very easily indeed; it was last registered in 2003, so the tyres are at least 8 years old. (I plan to re-VIN it on Monday after a brake thickness test, and I have Burt Munroed the tiny cracks in one sidewall of the rear tyre, with black boot polish. It looks good.) They feel pretty much rock solid, so the grip from them undoubtedly be almost nonexistent. Provided the polish trick works, I'll retyre the thing the following week with the Dunlop D250 180/60/16 and an as yet undecided 130/70/16 on the front. Looking at the existing clearances I will be very surprised if I have to do anything more than raise the front guard 6mm and turn the rear sprocket around, and relocate the front sprocket by the same increase in offset.
There are a few things wrong with the bike, maybe some someone can shed some light?
1) Clock doesn't work. Love that classic Italian electrics.
2) Front brake shudders. The discs were measured as flat by the Ducati guy in Napier. Perhaps a caliper retention issue? It's not major, and doesn't feel awful, but I would like it to be smooth. The shudder is not related to wheel speed.
3) There's a very slight movement (audible) from the top of the forks/head (I have no idea what that area is called) with the front brake engaged, rocking it back and forth. Could that be related to the shudder? I'll have it fixed when it's serviced this week.
4) The headlamp seems to be pointed straight at the sky, with low beam being far higher than a high beam should be. I had thought it might be the rear end too low, but my buddy who also has a 906 reckons the seat height is right, so I guess it's just falling out of alignment.
5) The clutch is rather odd. Which is, I take it "by design" and not a bug. I can pull away smoothly from idle using a very slow release, but it screeches a bit at times - which I take it is also "normal".
Anyway, the Paso still pulls the public's attention. I think I've done 45 klicks on the road, and already had more thumbs-ups and admiring looks from people than I think I had in all my years of riding riceburning revometers. I take it that people notice Ducatis a lot more than other bikes? Or is it particular to the PASO? I always thought the Paso was simply fabulous, and I almost can't believe I have these dreams parked in the garage. Well, not quite; the Lamborghini Countach LP400 will probably always remain a dream.
If I recall correctly, the Paso was so expensive in 1987, that I didn't even dream I'd ever own one. Instead I had a poster of the poor-man's Paso, the Honda VFR-750 : http://upload.wikimedia.org/wikipedia/c ... F_1987.JPG
Since the photos were taken I have polished it up using some very good carnauba spray wax, and Autosol on the pipes. It's come up pretty good for a 20 year old bike, even if I do say so. I'll post more pics when I've had the tyres done, and given a proper clean.
You'll undoubtedly see me here quite a bit; I seem to love buying exotic super-vehicles which suffer electrical issues, and have horrendous maintenance costs... So far I've spent 7 times what the Paso cost just maintaining the 928... I hope the new acquisition is cheaper.
So, greets all, from Christchurch, N.Z. - if there are any other Paso riders in town, I'd love to hear from you on 0210-69-58-69, or (03) 977-5513. Cheers.
