The pump is pumping fuel up to the Y connection and then straight back to the tank via the return. The hose to the carb is not blocked and the float valve is not stuck.
There are two pipes poking out of the underside of the tank - I connected the return line to the front one, and the breather (I assume) to the rear. Have I mixed them up?
It seems to me that for the system to work there must be a pressure regulator in the return line - is it in the tank?
Sorry if this has been asked before. I had a look at the Weberology topic to see if the answer was there.
The bike ran fine before I laid it up so I put some fuel in the carby bowl and put the top back on and it fired instantly and ran well.
Hope someone can enlighten me on what I've done wrong!
Cheers, CB
