Radiator Mount cracked
Colonial Boy
Post by Colonial Boy »
While refitting the right side fairing I noticed a crack in the bracket between the radiator mount and the frame:
It is an aluminium bracket but welded nicely with the Tig.
I suggest you have a look at your radiator mounts next time you remove your fairings, or if you are paranoid the brackets are visible with just the scoop covers removed. Here it is repaired, repainted and refitted:
Cheers, CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
Colonial Boy
Re: Radiator Mount cracked
Now I have refitted the fairings, I realise both sides are visble through the vents without removing the covers :thumbup:
CB
Ducati 906 Paso
Kawasaki GPZ900R
Triumph Sprint 955
du907
Post by du907 »
You bet'ca. Have done both of mine. Built it up a little thicker at the inside of the bend before grinding it down.
du907
