It is an aluminium bracket but welded nicely with the Tig.
I suggest you have a look at your radiator mounts next time you remove your fairings, or if you are paranoid the brackets are visible with just the scoop covers removed. Here it is repaired, repainted and refitted:
Cheers, CB
