I was checking out a 1999 Aprilia 250 this weekend and noticed that the wheels would actually look like a decent replacement on a Ducati which got me thinking about the awful tire choice you folks have with the 750/906 which I have offered my thoughts on else where already.
So why not the Aprilia
on the Aprilia Front suspension travel: 120 mm (4.7 inches) Paso 125mm
on the Aprilia Rear suspension travel: 130 mm (5.1 inches) Paso 135mm
Front tyre dimensions: 120/60-ZR17 Paso 130/60 -16
Rear tyre dimensions: 150/60-ZR17 Paso 160/60 -16
Front brakes: Dual disc
Front brakes diameter: 298 mm (11.7 inches) Paso = 280mm
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches Paso = 270mm
Obviously there is the sprocket, spindles and brake calipers to sort out but the dimensions seem more positive than negative and it's an idea.
Also on a positive side they seem fairly cheap and available as spares on ebay compared with some other alternatives and Italian (of sorts)
Okay lets discuss or ignore
