You dont , by chance live on the top of a hill , do you?
That`s a new one, good find!As it turned out the issue was with a badly worn key and shaft keyway for the pulley that drives the timing belt, which caused the timing to vary from correct to incorrect and hence I could get it to run sometimes but not others.
No sorry didn't take any from the side.Tamburinifan wrote: Setup looks tidy, any side pics?
