what are these holes for ?
My engine has 3 holes on the back. 2 small ones are on the height of the swingarm axle (I wonder if these are original) and there`s a big one on the bottom right.
My friends Cagiva Elefant 900 engine doesn`t have any of these.
Re: what are these holes for ?
Post by Tamburinifan »
Edit: Did not remember correctly....
jcslocum
Post by jcslocum »
Are there Allen screws in there??
it looks like there would be. Meanwhile I can´t check anymore as the swingarm and shock are back in place.
micklm
Post by micklm »
For two of them I would guess someone has created threaded holes for grease points to the swingarm pivot?
But I can't think what the third would be.
I don't have them on any on the various two valve crankcases I have.
Curious,
Mick
whitepaso
Post by whitepaso »
I have them on my engine too. I assumed the two at the top were either for non-installed grease fittings or to clamp the swingarm axle for ?? reason. Have no clue on the bottom one.
ok, that`s good to now. So they are probably original. Are yours open or is there a hex screw inside ? I was also thinking about grease fittings.
whitepaso
Post by whitepaso »
I'm pretty sure they have hex screws in them. I have a photo of the engine while I had mine apart but the resolution is not good enough to tell for sure.
21783mike
Post by 21783mike »
I happened to look at my spare engine and it appears that there are roll pins in the 2 small holes.... the other large one not sure what it was intended for, maybe an oil line?
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
