backfiring
backfiring
My right cylinder is backfiring does anybody have a clue why?? I swapped the igniters around it turns out its not them Could it possibly be that i need a valve adjustment?? If anybody has had this on there PASO please tell me what u did to solve the problem..Thanks Vince
- Desmo_Demon
Re: backfiring
"Right" cylinder? Backfiring through the carb(s) or the exhaust? If it is through the exhaust, how do you know which cylinder it is since the exhaust has an "X" collector that both cylinders go to?Vince wrote:My right cylinder is backfiring does anybody have a clue why?? .....Could it possibly be that i need a valve adjustment??
Whether it is the front (horizontal) or the rear (vertical) cylinder, check your belt tension first. My ST2 starts backfiring through the throttlebodies and the exhaust as the belts loosen up. If I do not adjust the belts between the 12k mile belt changes, it starts running really rough at about the 11k mark.
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Re: backfiring
Your right thank u ill check it out
- Finnpaso
- year: 0
Re: backfiring
My 705 Paso was backfiring ALOT when it had Weber. Many times i took keys out from keylock and after 2-3 seconds it make usually very big "BANG".... It was very funny, but i taught, that such can destroy something in engine.
But after i turned to Dellortos (and later to Mikunis) never since happen such. So, in my case it was that Weber, what made that backifiring.... It happened also when engine was hot and i made engine braking. Seems, that fuel "leaked" from Weber to inlets some way...
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
