750 paso parts left over
gitarded
Post by gitarded »
I ended up parting out the Paso. Still have some parts left if anyone is in need. Starter, triple trees, foot shifter and brake asembly, rear master cylinder, exhaust header, headlight cowl support etc etc.
Duc906
Re: 750 paso parts left over
Post by Duc906 »
Location?
fasterdammit
Post by fasterdammit »
Tell me about your rear M/C ... leaking at all? Good shape? How much do you want for it?
1988 Paso 750 #753965
1997 Monster 750
88WhitePaso750
Post by 88WhitePaso750 »
How is the clutch master cylinder? Do you have the rubber boot for the shift lever?
1978 Yamaha 650 Special
1987 Yamaha FZ600
1993 Suzuki GSX-R 1100
1995 Kawasaki Ninja 250R (wife's)
1988 Ducati Paso 750
2009 Yamaha FZ1
fasterdammit
88WhitePaso750 wrote:How is the clutch master cylinder? Do you have the rubber boot for the shift lever?
I'm pretty sure BevelHeaven carries them if you're looking to replace them.
1997 Monster 750
loki1957
Post by loki1957 »
how about a voltage regulator?
skibruce2
Post by skibruce2 »
I am interested in the gear shift lever from your 750 Paso. Do you know if it is the same as on the 907ie? How much are you asking for it?
persempre907
Post by persempre907 »
skibruce2 wrote:I am interested in the gear shift lever from your 750 Paso. Do you know if it is the same as on the 907ie? How much are you asking for it?
it's the same.
skibruce2
Post by skibruce2 »
