flat battery
jakarate1
flat battery
Post by jakarate1 »
Hi, my 750sport has a flat battery;can i charge the battery without removing from the bike
ducinthebay
Re: flat battery
Post by ducinthebay »
Yes, but you need to add a charging connection to the battery. If you buy a trickle charger, most of them come with a pigtail that you can attached to the battery and simply plug in when not in use. I keep most of my bikes on a battery tender when I'm not using the bikes much. I find the Sport to be really good on batteries. If your battery is several years old, it may just need to be replaced.
jakarate1
Re: flat battery
Post by jakarate1 »
thanks,the charging connection will i have to buy from a bike shop or can i get from a retail store?jas
Re: flat battery
Any automotive supply can get you a pigtail for a trickle charger.............
