ZDM-B06
ZDM-B06
Stock leftside exhaust. Brushed aluminum jacket. ZDM-B06
Any one have one they would part with?
nnnnnnorman
Re: ZDM-B06
Post by nnnnnnorman »
not me. good luck!
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Re: ZDM-B06
there are some on ebay UK. But as beat as they look they`re probably not worth the money if you had to ship to the states
http://cgi.ebay.com/Ducati-Paso-907ie-S ... 27b4eef992
(Norman, maybe for your next MOT ? :) )
englishstiv
Re: ZDM-B06
Post by englishstiv »
Oi G behave yourself!!! Those are mine and they ain't that bad looking either especially when considering some I've seen and that dent could be pulled with a little heat or welded over.
Having said that though they would be way too expensive weight wise to ship sate side unless you were really desperate.
I also have an original old mirror on there which came with my bike and an interesting repair was made with it by a previous owner probably the same time the exhausts got scratched up. The 906 front guard is fairly decent though and guaranteed a lot cheaper than most I've seen on ebay recently as a start price.
I was gonna post them on here but as you've highlighted them I'll leave the link on this thread.
DUCATI 907ie 1992
Ducati Streetfighter 955 V2
Re: ZDM-B06
sorry, maybe the dark pics make them seem worse as they actually are.
Here`re some modified ones if you`d like to change them
englishstiv
Re: ZDM-B06
G I've said it before and I'll say it again you spend way too much time sitting at that computer :lol: :lol: :lol: :evil: Many thanks for that though, you can see now where the spit and polish is needed, a bit of new rubber and a bit of dent pulling and a lick of paint. :thumbup: :thumbup:
DUCATI 907ie 1992
Re: ZDM-B06
tiv
Are those stainless covers? The ones I need have aluminum covers. I actually only need a cover. The muffler itself is in good condition. A friend of mine recently grabbed a handful of brake on the 907 and went down on the left side removing some of the cover. I could fix it but my thoughts are if I could find a complete muffler to replace the damaged one I could take the damaged one apart to see what would be involved in coring it.. I prefer the look of the stock exhaust to every other system I have seen but they are a little to quiet for my taste. :thumbup:
Duc906
Re: ZDM-B06
Post by Duc906 »
englishstiv
Re: ZDM-B06
Higgy
Mine are stainless, the one shown by Duc906 is the type you require if it's aluminum you are after they are also found on the early Monsters.
With respect to de-coring I did this with a 96 Monster 600 I had for a while, I actually made it a 2 into 1 and shortened the length of the silencer as well. The problem you have with these type of standard Ducati Silencers is that they are welded at the front and back internally so you would need to clean cut at the front and back end of the baffle de-core and then re weld both ends together, if you make a neat job you can also adjust so you can slip the baffle back in. I realised this after I had cut mine in half.
I kept the ones now for sale as I was going to do the same myself and also sort the dent out in the body but then I luckily found a brand new unused set to play with.
Here is what my monster ended up like as you can see I cut the outer plate so that all the Ducati spec data was still visible.
Sorry but for some reason the 1st photobucket image is a bit to big even though I had tried to sort it --------moderators can you fix it?
DUCATI 907ie 1992
Re: ZDM-B06
Is this what you are after Higgy,
Could be, I am waiting on a response from the guy on if it is a ZDM-B06 or not
Hey G, Do you know if the 750 cans in this style are the same as the 907?
Never mind, I went back and checked out the entire listing,a little farther down the page is the picture showing it is a ZDM-B06
I bought it :lol:
Thanks guys..............
Re: ZDM-B06
you mean from the second auction ? It`s shown on one of the pics.
Sorry, i don`t know if there are indeed differences in the silencers.
If so it can`t be much as the headers have the same output diameter. The frames are basically the same as are the footpeg brackets. So it could only be a different inner or outer diameter. I`d guess the internal design would be the same.
Re: ZDM-B06
ZDM-B02 arrived today and is on. All is cool and is Identical.
Tomorrow or the next day(or maybe the day after :wacko: ) I will take the scratched cover off the original and cut the end cone off to see what's involved in coring it.Then decide to stick it out with the coring or clean up the F1'S or refab the Staintunes or just start from scratch.
Re: ZDM-B06
Here is the dissected unit
Re: ZDM-B06
Post by Tamburinifan »
I had a friend weld my OEM 907 mufflers to be straight flowing, cut away diffusion chamber etc.
Too little opening straight through, I guess, quite lame sound & performance.
Not worth the trouble IMHO.
F1 easy to work with but go w the Stayintunes, looks better.
Re: ZDM-B06
Both sets need alot of work :dunno:
I am actually thinking about putting the internals of the F1's in the stock cans and just opening up the stock end cap to its outer ring :shock: :shock: :shock:
