Earlier today I finished the wiring upgrade on the Paso and took some shots of the finished article.
The relais and the fuses on the electronics plate:
The relais at the coils:
Checked and double-checked after everything was connected and held my breath pressing the starter button: Success!!!
It works a treat and I'm pretty stoked that it all worked first go. I used crimped connectors and shrink tubing on the joints. During the upgrade I also took apart all the connectors and cleaned all the contacts.
As always, the information on this forum is absolutely fantastic in keeping a Paso running!
Mike
