belt tensioners and idle pulleys anybody?
nnnnnnorman
ive been told it would be a good idea to change my belt tensioners and idle pulleys while im at my engine overhaul. has any body got any they want to sell or can recomend a supplier? its a 906. thanks.
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
- ducapaso
Re: belt tensioners and idle pulleys anybody?
Why not original spare parts?
belt tensioner are standard bearings available anywhere, idle pulleys should be worth for less tham 100~120 usd
ex...Red "smooth" 753349
nnnnnnorman
thanks nicola its an option worth considering if no one has any laying around gathering dust and lookin for a new home.
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
I thought about replaceing those too but the idler on mine the mounting bolt and the roller were one part assy and bloody expensive ....... so they are still there
Just as McTool says, the one-piece bearing (SKF as std) is expensive as it's probably peculiar to our 2v engines (around £35 from Ducati) but the other side-by-side bearing (i.e. 2 required per belt) can be obtained anywhere (as ducapaso has said) for less than at Ducati dealers. The company 'simply bearings' has a good reputation and I would certainly recommend that you try them.
nnnnnnorman
thanks giocast all usefull information there.
i am working to a budget so the side by side option sounds like a winner.
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
