not a 100% sure about the technical differences, I guess the P8 has few features that the P7 does not have.907pasonut wrote:how different is a p7 to a p8?...or what are the advantagesangelix wrote:
Actually it could be beneficial UPgrading to a P8...
I see the swap more from and AGE point of view, the P7s were used on Ducatis around 1988-1992. the P8 came later therefore it will be less dated from the electronic components point of view.
As fare as the chip programming (Dyno) is concerned I remember asking around and I was told a couple of "I am not sure, will need to check" when i mentioned P7, whilst for the P8 it was always "no problem".
Last but not least, when I was after a P7 it took to me a long time before finding a good one; P8s were all over the place and they were also cheaper.
I am happy you disagree, but the point is that ANY EFI is 100 times more reliable and practical than ANY carb setup.Tamburinifan wrote:I disagree.the EFI on the 907ie might not be perfect but it is much better than any carburator setup.![]()
My M900 f FCR & Ignitech works far better than a original 907 w P7.
I would not change to carbs either, get a good chip.
with few changes on a PC you can adjust your settings to whatever setup you have on your bike and can revert those settings in less than 10 minutes.
You cannot do that with the carbs... although I AGREE with the fact that carburators could give a smoother ride when picking up the revs our of tight corners; this effect is very tipical of the old EFIS, now adays the riding experience is much smoother.
