From http://www.visi.com/~moperfserv/955_sps.htm .one way to overcome this problem is with dual injectors. The P8 computer (found on the '93 and 94 888s and the '95 916s) is capable of firing dual injectors sequentially, which is; one injector per cylinder is used at the 'map' injector time, up to a certain injector time (that point is set by the software on the 'chip'.)
I would like to see how a 900 2v w FCRs & the full ignition map from a ECU runs.....
