Upgrading a 907ie
Upgrading a 907ie
Evening all,
Not been on here for quite a while as my 907 has been in storage for a few years.
This leads me to my question. If I were to find myself in possession of a 907 which had been sitting for a while, and an ST4S which is working well but which (while quite legally owned) is not UK registered and I decided to use the ST4S to upgrade the 907, how far do you think I could go?
Ohlins forks, front brakes, Ohlins rear shock, light 5 spoke wheels, ally swingarm, 996 motor... how much has been done before? Is it straightforward? Could I for instance just fit the ST4S yokes and whole front end? What about the 996 motor in the 907 frame - does it fit? I'd have to use the ST4S ECU/key/antenna/immobiliser etc I guess.
I appreciate it might not be the sensible approach but that doesn't normally stop me...
Any thoughts gratefully received.
IanE
IanE
Re: Upgrading a 907ie
why dont you just fit the 907 frame to the st4s?Surely it would be heaps easier to change that one part than to take all that stuff of the st and then have to fit it all to the 907
hello ian that sounds like an interesting project. did you win that german bike on e bay? good luck. if it can be done the people on here will help you.
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Yup, it's the German one on ebay but that was me selling it recently. :-) Unfortunately the buyer (who drove from Inverness to Gloucestershire) decided the clutch rattled too much and declined to buy it. What can I say? It's absolutely fine. I've checked the basket and I've seen a lot worse.nnnnnnorman wrote:hello ian that sounds like an interesting project. did you win that german bike on e bay? good luck. if it can be done the people on here will help you.![]()
I bought it via ebay a while back. I planned to register it here which requires either a certificate of conformity or an MSVA test. Ducati have been extremely unhelpful and have refused to issue a CoC (I've tried Ducati in Bologna, Ducati UK, Ducati Germany which goes back to the factory anyway, a UK dealer, and a German dealer, Ducati Hamburg, with no luck) and I haven't got round to the MSVA - it's a 3 hour test which I'd have to go 60 miles each way for, and stay throughout to twiddle stuff while the examiner examines. Not sure I can face it! The options are to flog it whole or in bits, o frframe it with an ST4S frame, or use the bits on the 907ie.
Just thinking out loud at present.
- ducbertus
reading all this, you're running out of options.
MSVA test maybe? if you get the ST4S registered you can try to put on the 907 plastic, to convert it into a "907". this maybe easier as trying to put everything into a 907 chassis. ST front end won't fit. the diameter of the stem is different and the 907 probably has no sufficient room for the triple clamps between the electronics on the left side and the coolant reservoir on the right side. Also the electronical connectors and wire looms are quiet different.
Bertus
Bertus
Although I appreciate that attitude,I appreciate it might not be the sensible approach but that doesn't normally stop me...
parting out the ST is the easiest way out.
I have seen a ST3 motor in a 907, though.
to the un trained ear(like mine) ducati clutch rattle does sound worrying. ebay sales can be a bit of a nightmare. people should always view the vehicle prior to bidding. i was half tempted by the bike myself but as you state, the way forward is quite problematic. why dont you, as a suggestion, sell the st4s vand put the cash or some of it into recommisioning the 907? breaking the st4s will bring in a fair bit of cash.
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Hey nnnnnnorman I had to laugh at your comment 'should always view a vehicle prior to bidding'. The guy working on my 907 (the '1 owner, 1900 miles from new' etc etc) turns out to be a little bit of a horror story. The mechanic removed the fairing panels (never went to the auction or I would have too . . .) to discover that at some point in its life the engine had caught fire. All the electrics were destroyed and the wiring that replaced it is all very amateur - apparently. Tank and some panels almost certainly new, paint must be.
More than a little miffed but - my own fault - didn't check it properly - the re-commisioning bill just went up!!
The 916s - which I know has been used on the track and expected to be a bit of a dog - has (apparently) never been dropped and always been - as far as can be told - very well maintained. Clean as a whistle and sounds like a snarling dog.
How can I have reached this age whilst being this stupid?
NO! Don't answer that!
Rhino
If God rides a Harley . . .
Then the Devil rides a Duke!
- persempre907
Rhino,
you're not alone.
I so bought my black 907.
I was quite lucky because I found out only the fork was flabby.
My great friend nojapan fully overhauled the fork for me.
As I told, you're not alone: often the bikes are like the girls.
We fall in love for without knowing we are doing...
And sometimes we wake up the morning without knowing who's the girl in our bed
you're not alone.
we all do it rhino from time to time. sometimes its a winner, sometimes its a loser. you're the lawyer.
any misrepresentation from the seller or owner? people pull all kind of stunts in order to sell a vehicle. good luck with it. and im glad the other bike is a good un!
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Appreciate the thought nnnnnnorman. But auctions are "Sold as Seen" and I wasn't there! I got a great bike for a bit too much money - do I really care? Nope. I didn't buy it as an investment (or I'd have spent the £3K on Claret) I bought it as a bike, and hey, sometimes they break. I just got this one a bit broke. I still love her and I will enjoy enjoy her greatly come the Spring/Summer - especially when we all organise a run. Be great to put some faces to some names.
And
Francesco - hai ragione !!!!
And
Rhino
- 907pasonut
Francesco...hai propio ragionepersempre907 wrote:Rhino,
And sometimes we wake up the morning without knowing who's the girl in our bed![]()
Rhino, it is a bit disappointing...but Im sure the bike will came up good again, its the same as my 851 I just bought, there is always something that needs to be done
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
- persempre907
Grazie a tutti!!!!
- JoKing
I got a 907 i.e. engine conversion to ST3-engine.
I did that about 4 years ago.
In december, I totally disassambled the bike for restauration.
Regards,
Johannes
Regards,
Johannes
Since you have the same nick I guess you are Joking from Motor-Talk.de?
I`ve been waiting for you to show up here, welcome!
Tell us ALL about your fantastic engine switch in a separate thread w lotsa pics please!!
Any problems so far?
