The best way to check a speedo is compare with a gps navigator. cancel all driving records and then put it in your poke.hardo wrote:Colonial Boy wrote:Hi Greg, well it hasn't yet.bevelheadgreg wrote:Spaggy at the Ducati Owners Club and others reckon tyre growth at speed/temperature means the tyre will foul the brace at the front/pivot nd of the swing arm
Cheers, CB
Hi CB
- did you tune or check the speedometer after the conversion?
- is the sidestand working or is the angle know very different than before the conversion (or did you extend the side stand / central stand in any way)?
- I will try the same concept as you did in respect of the tire / wheel modification. Whenever you put some additional miles on your bike it would be very interesting if you could describe us your experience with the new set of tires and any possible problems observed so far (of course I hope that there are no).
Thanks a lot for your feedback and you really did a great job on how our 906 pasos finally could get rescued!
Hardo
At the end of the ride it will tell your best speed
