..hardo wrote:hi everyone:
for those who are in switzerland. it is very easy to get an official okay from the vehicle inspection here in ch for the avon combination - hence, everything is fine for insurance etc too. they do except the ducati germany certificate. you only need to send them the registration document and they put a remark in it (the remark is necessary because of the larger rim of the paso in respect to the tire). you can do it via mail (this is what I did), you do not need to show up with your bike. i guess that should be possible in eu-countries too - but of course you need to check if this is a way you would like to go th solve the paso tire problem.
all the best, hardo
Hello Hardo, I have done the same with Tyres and altered my centre stand by 20 m in height, I have a 40 and 15 teeth gears, but I can not alter chain, its to tight with 106 and the wheel /tyre jams on swinging arm or I add a link 108 and its far to slack. Am I missing the obvious ? the chain is the original and perfect with no visable stretch or wear, any help would be welcome thanks Barry
Bought a new chain today 108 x 520 Still to slack and it will only get longing, I will try 106 and a 14 x 40,
strange that you got yours chain right using 108 with 15 x 40 , I have just no more adjustment left to tighten chain, 106 on the 15 x 40 jams tyre and will not clear , any help most welcome.
