Starter not engaging.
clay7185
Post by clay7185 »
I have a 91 907ie and the starter seems to only engage for about 2 revolutions before it cuts out the starter keeps spinning but the engine doesn't what could the problem be?
Also how do you test to see if ignition coils are bad (ohm resistance etc)?
Re: Starter not engaging.
sounds like the starter sprag clutch. Just search the forum.
ducbertus
Post by ducbertus »
G. is mentioning one possible cause.
the other can be that the starter turns to slow due to loss of voltage.
this can be caused by worn brushes, bad contacts.
also about this can be found on the forum.
Bertus
JoKing
Post by JoKing »
ducbertus wrote:G. is mentioning one possible cause.
Bertus
Yes, i think this is the case. I had that several times. After nuying a new battery, all went well.
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
The 907 has most of the "fix's for electrical issues as is.
But the only fix for the passage of time is maintenance
Clean those grounds and connectors. You will have far fewer issues :thumbup:
ducbertus
Post by ducbertus »
and disconnect the clock ( orange wire) as the clock drains the battery rapidly.
Bertus
ducbertus wrote:and disconnect the clock ( orange wire) as the clock drains the battery rapidly.
Bertus
Oh , you actually had to disconnect your clock :?: :!: I thought they all crapped out long before the battery had a chance to go flat :lol: :lol:
never understood what probelms all guys have with their clocks. Mine is just fine and there`s never been a battery problem even if the bike wasn`t started for a few weeks.
907pasonut
Post by 907pasonut »
under the seat there are 4 fuses, remove 2nd (from right) and clock will be disabled.
I remove the fuse during winter.
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
907pasonut
Bertus
actually...thats the main reason I disconnected the clock, I didnt want it to break down :beer:
Cheers Claude.
Jaffa
Post by Jaffa »
I think you guys with clock problems are missing something deeper.
My bike gets ridden only every few weeks at the moment with periods of up to a month without a start. The battery has never discharged to a degree where the bike wouldnt start. Perhaps its time to look further into this mystery that affects bikes in the Northern Hemisphere.
:zip: :zip:
:banghead:
Jaffa
'91 907ie (RED)
'82 900 Mike Hailwood Replica
Volvo aware Motorcyclist
It has been my experience with my 907 if the idle is too low,low enough to get a flickering charge light at idle the charge on the battery lets the clock draw it down to no start in about two weeks.
persempre907
Post by persempre907 »
907pasonut wrote:under the seat there are 4 fuses, remove 2nd (from right) and clock will be disabled.
I remove the fuse every time I stop the bike.
Why do spoil the battery?
