Any advice on what tyre pressures to run on 750 Paso. Am 16 stone
34 Front. 38 Rear ???
Tyre pressures
Tyre pressures
1990 750 Paso #754364
2005 BMW 1200RT
2005 BMW 1200RT
Re: Tyre pressures
normally I would just tell you to download the manual(s).
But yes, it´s correct.
Congratulations for the new bike. Hope it`s a good one.
Re: Tyre pressures
+/- 2 psi Big guy
Re: Tyre pressures
yep, a bit more than recommended in the front seemed to make handling a little better with the old tires.
- year: 1993
Re: Tyre pressures
A few more PSI probably made the profile a bit taller.............. like the alternate size fitted to the blade !
Re: Tyre pressures
not so much more
3psi are sufficiant. According to tire manufacturers and dealers I talked to in the past this is in limits that will not make much difference in wear.
Re: Tyre pressures
Thanks for the advice. i had looked in the manual but asked because I wonted to tap into the experience of others who, like me, might not be as slender as they used to be :-) I run my R1200RT with slightly higher pressures as it handles much better that way, especially two up
2005 BMW 1200RT
2005 BMW 1200RT
Re: Tyre pressures
I'd be happy at 16 stone only another 3/7 to go from 20 a year ago
