Trip Reset Nut part number
Does anyone have the Trip Reset cable nut part number - this is the nut that secures it to the dash filler,
fits on the knob.
Can't find it in the parts manual.
fits on the knob.
Re: Trip Reset Nut part number
it doesn`t have one. Something similar was justed asked in the 907ie forum and I`m afraid the complete reset cable is part of the dashboard. There´s no part number for that, either.
Thanks. That sucks.paso750 wrote:it doesn`t have one. Something similar was justed asked in the 907ie forum and I`m afraid the complete reset cable is part of the dashboard. There´s no part number for that, either.
Took the dash out to repair the odometer and then I think I screwed the nut back on
and taped the cable to the frame - drove it without the fairing for a couple of weeks.
I guess the vibration worked it loose.
Anyone have an extra one to sell?
if you`re lucky some hardware store may have round nuts that fit. It will for sure look different though. Probably like this
Grainger in the US should have one or McMaster Carr.
paso750 wrote:if you`re lucky some hardware store may have round nuts that fit. It will for sure look different though. Probably like this
Do you have a photo of the original?
BTW - do you guys think vibration could break it loose if it was tightened on the knob (but not mounted on the filler plate).
Didn't pay much attention to it so I don't remember if it locked in place.
If it's unlikely it fell down it should be around here somewhere.
Seems to me there is a fiber washer to keep it in place,so if the washer or the filler are gone,for sure
there`s one warped thin washer that`s missing here.
Thanks guys.
Guess it fell somewhere.
- JoKing
Yep... if someone finds the cable...please msg me.
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
- streetsurfer
Take a look under the fairing and tank . Oftentimes a part may lodge somewhere on it's way to the ground. Let's hope that's your case.
I think you could find a suitable replacement at most good hardware stores in the way of a jam nut. Can't recall the specific name for that type nut. apply soft loctite to the replacement maybe. many toggle switches use a similar nut, if you can find the right size.
streetsurfer wrote:Take a look under the fairing and tank . Oftentimes a part may lodge somewhere on it's way to the ground. Let's hope that's your case.
I think they're called knurled nuts.
Interim solution - rubber washer.
- trip cable.jpg (61.8 KiB) Viewed 9912 times
- Desmo_Demon
A threaded, knurled nut from an electrical toggle switch from an auto parts store may work,too. It looks similar to the ones on my guitars' potentiometers (volume and tone knobs).
2002 Ducati 748 monoposto
1998 Ducati ST2
1996 Suzuki GSXR-1100
1994 Bimota DB2
1988 MegaPaso 916 project
1987 Ducati Paso 750
1985 Harley FXEF
2001 Ducati M900ie (wife's)
2000 Yamaha YZF-R1 (wife's)
1998 Ducati ST2 (wife's)
1994 Suzuki GSX-750R (wife's)
1998 Ducati ST2
1994 Bimota DB2
1985 Harley FXEF
Electric guitar toggle nut - a touch too small.
- schecter nut s.jpg (106.26 KiB) Viewed 9911 times
