Can anyone give a quick but well informed answer to this naiive question:
Is the bottom-end of the 750 the same as for the 907? Can I rebuild the heads from the 907ie onto a 750 bottom-end, with all its auxiliary stuff like water pump??
thanks
Easier to get an answer here than hope I get the answer right by inspection / documentation review.
Bottom-end compatibility 750 <> 907ie
907ie toolkit owner
Re: Bottom-end compatibility 750 <> 907ie
no it`s not.
The 750 is an oil cooled, 5 speed gearbox engine with 88mm pistons, the 907ie is a water cooled, 6 speed gearbox engine with 92mm pistons.
Due to the different gearbox the 907ie engine case is a little wider and the cylinder stud distances are bigger due to the larger pistons. Of course the engine case opening for the cylinders is also larger.
907ie toolkit owner
paso750 wrote:no it`s not.
Ok thanks, thats the sort of definiitive answer that makes being on a forum so worthwhile.
Tom
