Can anyone help identify a brand new spare silencer I have please? The part number is 037084105, it seems identical to an original Paso 750 silencer except that it has 2 studs instead of a welded on mounting bracket and doesn't have the built in lugs to clamp it to the exhaust pipe. I have photos I can post if it will help.
I bought it from ebay several years ago as a spare, however I've since had 2 bespoke stainless silencers made so no longer need it. I'll be putting it either in the 'For sale' section or back on ebay once I know what it is!
Thanks,
Martin Philp
750 Paso since 1989
Paso/Sport silencer
Re: Paso/Sport silencer
can`t find the number in the P750 or 750S parts catalogue so a photo may help.
Possibly from above as the connection to the header is different on both although the rest looks the same.
macchiman
- year: 1989
Thnaks G, here are the pictures (I hope!)
Martin
Martin
the one starting with 0370.xx is from a P750. The one with 573.xxx is the right one from a 906.
good luck to you mate
keep an eye to ebay and ask on the paso.org..... take your time,don't jump on the first set you find........
